Forums >> Revit Building >> Technical Support >> Lighting Fixtures will not emit any light
Mon, Jun 6, 2011 at 6:41:48 AM | Lighting Fixtures will not emit any light
Whenever I render my hall way on draft or on any setting, the lights that I have put in will not emit any sort of light to illuminate the area. I've tried changing parameters, putting in new lights, duplicating and changing lights. I've even changed the intensity of the lights. If anyone can help me figure out why they won't emit light, it would be greatly appreciated. If anyone has lights that work when rendered will also be greatly appreciated!
      10542892
Wed, Jun 8, 2011 at 12:10:28 PM | Lighting Fixtures will not emit any light
If you search the forums, you will find several similar threads.
  1. First question, is this really a light or is it just named as a light?  Open the family and see if it has a light source.
  2. Second, is this light source surrounded by a model material - like a lens?  If so, what is that material set to IN THE PROJECT.  The project rules so it doesn't matter what it is set as in the family.   Does this material have transparency settings?
  3. Finally, if this is a ceiling hosted light and the source is above the ceiling plane, does the light cut a hole in the ceiling?
Light can not penetrate solid, non-translucent/transparent objects!
turning on light fixtures
Wed, Oct 16, 2013 at 10:53:10 PM
The lighting fixtures wont show up in my final revit 2013 rendering.
Wed, Jul 31, 2013 at 3:23:18 AM
How do I get my down lights to emit light in a rendering?
Thu, Jan 13, 2005 at 11:24:41 AM
Creating custom lighting fixtures (What creates the light?)
Sun, Nov 4, 2007 at 1:51:57 PM
Tagging Lighting Fixture Symbols in RCP
Fri, Dec 18, 2009 at 1:03:01 PM
Page generation time: 0.4555
