Forums >> Revit Structure >> Technical Support >> REBAR SCHEDULE HELP!!!!!!!!!!!!!!!!!!!!
Sun, Jun 5, 2011 at 8:49:07 PM | REBAR SCHEDULE HELP!!!!!!!!!!!!!!!!!!!!
fender316
I AM TRYING TO SET UP A REBAR SCHEULE FOR A SMALL PRECAST BUILDING.  THE ONLY THING I CAN GET TO SHOW UP IN THE SCHEDULE IS THE "MARK".  THE PARAMETERS I HAVE SET UP FOR THE SCHEDULE ARE....
MARKSIZESHAPELENGHT (IN)FRONTREARLEFTRIGHTFLOORROOFTOTALTOTAL WEIGHT (KG)
I BASICALLY JUST NEED THE SCHEDULE TO COUNT EACH PIECE OF REBAR IN EACH WALL, GIVE THE REBAR LENGTH, SHAPE AND SIZE.  IF ANYONE HAS ANY WAY OF HELPING IT WOULD BE MUCH APPRECIATED.
THANKS!
Thu, Oct 4, 2012 at 6:15:25 AM | REBAR SCHEDULE HELP!!!!!!!!!!!!!!!!!!!!
nate1hardrada
CHECK TO MAKE SURE HIDDEN IS NOT CHECKED IN YOU FORMAT.
Rebar Schedule - Right click to Show rebar in View - I see no "Show... " option
Sat, Nov 22, 2014 at 3:28:11 PM
Rebar Schedule
Thu, Oct 4, 2012 at 6:12:39 AM
rebar schedule ????
Tue, Feb 7, 2017 at 10:34:19 AM
How to add unit weight as a parameter in rebar schedule?
Thu, Oct 4, 2012 at 6:19:37 AM
Revit 2016 - Rebar note
Wed, Jul 29, 2015 at 9:21:12 AM
Page generation time: 0.1509
