Forums >> General Discussion >> Revit Project Management >> Having problem with realistic style mode in Revit Architecture 2012
Sat, Jun 4, 2011 at 11:58:42 AM | Having problem with realistic style mode in Revit Architecture 2012
Rakesh
4 Stars: 1 Votes
when i chenge the model display style to Realistic, its acting as Shaded style.. Before It used to work properly, when i closed n opened the file, its coming like this... Other display styles are working roperly except for realistic. I am having the same issue with some other files as well but not all of them.. Please help.. I have attached 2 images, one is before render and other is after render just to show whats happening to the material..
Sat, Jun 4, 2011 at 5:56:58 PM | Having problem with realistic style mode in Revit Architecture 2012
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Looks like you have made everything as existing. Existing does not take on color.
Sat, Jun 4, 2011 at 6:12:45 PM | Having problem with realistic style mode in Revit Architecture 2012
Rakesh
4 Stars: 1 Votes
I'm sorry I didn't understand you. What do you mean existing? I didnt change any options as far as I can remember, after closing and then opening it again, it turned out to be like this... Most of my other files became like this too except for one...
Sat, Jun 4, 2011 at 7:38:58 PM | Having problem with realistic style mode in Revit Architecture 2012
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
select an object look in properties box for phasing. if it says existing then that is likely your problem. look in help file about phasing. I think you will find a simple way in there to move all the objects to a new construction phase without having to select them all. Good luck
Sat, Jun 4, 2011 at 8:23:29 PM | Having problem with realistic style mode in Revit Architecture 2012
Rakesh
4 Stars: 1 Votes
I tried changing Phasing but seems like thats not the problem, nothing happend related to the realistic material texture.
Sat, Jun 4, 2011 at 9:04:44 PM | Having problem with realistic style mode in Revit Architecture 2012
mcantwell
mcantwell Avatar
Rendered output is unrelated to view style.
Realistic is supposed to look more like a rendering so you don't have to render to get a "realistic" view.
I don't understand realistic view because mine never look real. Must be missing something.
To get the rendering looking good you need the render materials, lighting and settings sorted out.
Sat, Jun 4, 2011 at 10:15:52 PM | Having problem with realistic style mode in Revit Architecture 2012
Rakesh
4 Stars: 1 Votes
@mcantwell - I attached a rendered view just to how how the facade treatment actually should be when i am in realistic view. So even are you having same problem that im having?
Tue, Jun 7, 2011 at 9:01:06 PM | Having problem with realistic style mode in Revit Architecture 2012
dgolbs
yes i am also having the same problems. all my materials are corect. there must be something im not seeing.
Tue, Jun 21, 2011 at 10:35:01 PM | Having problem with realistic style mode in Revit Architecture 2012
jfcarch
In options (under the big R), under Graphics tab, the ''use hardware acceleration'' must be checked. However, you might have some problem with element sections.
Wed, Jun 22, 2011 at 8:04:36 AM | Having problem with realistic style mode in Revit Architecture 2012
keyaggie
Ditto what jfcarch posted.
However, I noticed really bizarre behavior of the Revit when platform when I checked the box like not being able to select anything.  Oddly I can select things now, but it takes a few clicks to get just a roof highlighted.  With Acceleration unchecked, it runs smoothly as it should.
Revit Architecture 2013 extremely slow in 3d Realistic View ambient and sunlight
Fri, Mar 8, 2013 at 8:36:48 PM
Realistic Style Help
Mon, Aug 30, 2010 at 8:41:35 AM
Architecture 2011 and 2012 problem
Tue, Aug 23, 2011 at 5:49:33 PM
Question about sketch Mode
Thu, Jan 17, 2013 at 6:34:56 PM
Filled region not showing in elevation realistic mode
Wed, May 15, 2013 at 1:55:02 AM
Page generation time: 2.5780
