Forums >> Revit Building >> Technical Support >> Can't creat multistory stair
Thu, Jun 2, 2011 at 1:27:30 PM | Can't creat multistory stair
rabbitcookies
I want to create a ordinary stair from level 2 to level 4, both levels are 3000mm at height.
I create a stair from level 2 to leve 3 and it is fine. After finishing it, I click the stair and try to change Multistory top level to level4, but I get the warning as:
Multistory stair/ramp could not reach its top level w/ integal number of flights, maximum number of flights below the top level is created.
I don't understand the warning and is anything I did not right to create multistory?
Thanks in advance
Thu, Jun 2, 2011 at 3:16:52 PM | Can't creat multistory stair
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
make one level change copy to next level
Mon, Jun 6, 2011 at 11:47:07 AM | Can't creat multistory stair
emgeeo
3.5 Stars: 7 Votes
welcome to the club!
Mon, Jun 6, 2011 at 12:43:55 PM | Can't creat multistory stair
Don't just copy the stair.  If the stair has no more than two runs, then you should be able to just set it as multi-level.
Did you set this stair to go from level to level?
Stair Riser/Tread Number in Multistory Stairs
Tue, Sep 13, 2016 at 9:47:54 AM
Handrail Supports on Multistory Stairs
Tue, Jun 24, 2014 at 3:10:16 PM
Stairs - Multistory Monolithic Rev 2014
Mon, Dec 30, 2013 at 8:48:35 AM
how to creat a doom roof
Mon, Sep 8, 2008 at 4:39:08 PM
multistory stairs skiping levels
Sat, Jun 17, 2017 at 6:28:57 AM
Page generation time: 2.6289
