Forums >> Revit Building >> Technical Support >> Adjusting Layer Heights
Thu, Nov 17, 2005 at 9:48:43 PM | Adjusting Layer Heights
Audrie
I am working on a drawing that someone else (also new at Revit) started. The gound floor plan is set at 240 for some obscure reason and I want to readjust it to 0.0 It won't allow me to do this. It tells me it can't form an angular dimension !?? The layers look to be locked every time I touch them, even though I have previosuly unlocked them. Any ideas?
Thu, Nov 17, 2005 at 9:50:18 PM | RE: Adjusting Layer Heights
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Does the entire project need to move or just that one level? If its the entire project just use the relocate project tool in the "tools" drop down.
Thu, Nov 17, 2005 at 11:11:03 PM | RE: Adjusting Layer Heights
Audrie
Thanks for your response Mr Spot. It is just that one level, the beam level is at 2400, and the ground floor level is at 240, so just now there is only 2160 between the two. I need to drop the ground floor to 0 to allow 2400 clearance. I thought these levels could be readjusted easily.
Fri, Nov 18, 2005 at 12:19:00 AM | RE: Adjusting Layer Heights
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When it says can't create angular dimension does it give you the opportunity to delete and continue? If not indentify its ID number then use select by ID to delete it and unconstrain....
Changing Level Heights
Mon, Jun 18, 2012 at 10:55:28 AM
Exporting and layer modifiers
Wed, Nov 16, 2011 at 4:04:33 PM
LAYER PULLDOWN
Tue, Feb 14, 2012 at 3:16:22 PM
How to control a single-layer wall?
Wed, Apr 28, 2010 at 2:39:50 AM
one roof two wall heights
Mon, Apr 6, 2009 at 11:34:59 PM
Page generation time: 0.0873
