Forums >> Revit Building >> Technical Support >> Blank spaces in topography
Thu, Jun 2, 2011 at 1:16:07 PM | Blank spaces in topography
assoulinder
Hello all,
New to this Forum, Appreciate any assistance.
I can't figure out why a level view that cuts through the toposurface shows blank spots where there are pads in the levels above.
Using Revit Architecture 2011.
Help please!!!
Thu, Jun 2, 2011 at 1:23:13 PM | Blank spaces in topography
Pads cut topography.  If the pad is above the topo, then there will be a hole.
Thu, Jun 2, 2011 at 1:33:46 PM | Blank spaces in topography
assoulinder
Thanx,
Yeah, I get that. Is there anyway to make it appear filled? it looks funny in the level plan. I don't get the logic behind it.
Thu, Jun 2, 2011 at 1:42:31 PM | Blank spaces in topography
If you are not going to cut your topography, then maybe it should not be a PAD.
Should this be a filled area?
Thu, Jun 2, 2011 at 2:32:01 PM | Blank spaces in topography
assoulinder
Maybe I'm not explaining myself correctly... I do cut the topography with pads, but I have many levels, and I don't want to see the
blank space that the pads leave in the plan views of levels that are below these pads . I just want to see filled earth, because there
is no reason to see them in the plan views that are under tham...
Also, for some reason, one of these above pads does not leave the blank spot, eventhough it is defined correctly and cuts the topo.
Thu, Jun 2, 2011 at 2:37:23 PM | Blank spaces in topography
I see now.  Have you ever used plan regions?  You can use that to show the topography all the way, or simply use a filled region.
Thu, Jun 2, 2011 at 3:00:14 PM | Blank spaces in topography
assoulinder
I have not. Thank you, I'll look it up.
Night Smile
Camera View shows blank spaces?
Fri, Mar 27, 2015 at 6:06:57 AM
topography in elevation shows up "blank" space. any work around?
Wed, Apr 29, 2009 at 3:20:42 AM
12
Revit Spaces Elec VS Mech
Tue, Feb 2, 2010 at 10:50:50 AM
dimension text format, remove extra spaces
Tue, Aug 24, 2004 at 8:38:42 PM
Multiple Parking spaces - line based family, need help
Tue, Jul 29, 2014 at 4:34:35 PM
11
Page generation time: 1.8543
