Forums >> Revit Building >> Technical Support >> How to fix up incorrect wall lines
Wed, Jun 1, 2011 at 3:20:46 AM | How to fix up incorrect wall lines
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Hey guys I no there is a tool to fix this I have been looking for ages and cant find it. When you place down a few walls and the lines dont stop at the correct spot ( see attached ) how do you "trim" them?
Revit 2018........
Wed, Jun 1, 2011 at 7:19:15 AM | How to fix up incorrect wall lines
Drag the end of the wall back, or if their is an intersecting wall, drag the wall back and use the extend tool to meet the two walls.
Wed, Jun 1, 2011 at 12:52:28 PM | How to fix up incorrect wall lines
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Also, know that multi-story walls might be connecting to other walls above or below where you're working, and not cooperating for that reason.  Usually it's best to make floor to floor walls, especially in the interior of your building.
There's also a "wall join" tool.  It's under the Modify tab, in the Geometry section.  The pencil pointed toward the angle.
This will allow you to highlight your wall join, and force revit to cycle through the possible join scenarios.  Odds are a few clicks will bring you to something suitable.  experiement with mitre too.
Wed, Jun 1, 2011 at 5:58:57 PM | How to fix up incorrect wall lines
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Thanks heaps guys miter worked a treat. Much appreciated.
Revit 2018........
Incorrect rotation on materials
Tue, Oct 30, 2018 at 3:11:23 PM
Basic Wall as Curtain Wall panel transparency incorrect.
Wed, Nov 23, 2011 at 9:37:16 PM
Incorrect Perpective views. Appearing out of proportion.
Sun, May 31, 2009 at 8:05:03 PM
Stair Handrail Extension - Incorrect Height
Tue, Mar 14, 2017 at 3:41:27 PM
Walls' projection lines - how to turn them off?
Wed, Jun 26, 2013 at 4:00:09 PM
Page generation time: 0.7784
