Forums >> Revit Building >> Technical Support >> is there any way to transfer family object to instance object or something like
Tue, May 31, 2011 at 9:31:01 PM | is there any way to transfer family object to instance object or something like
gates1412
As you know, I may set up the low poly scene in revit and export it to max to make some details. And sometimes I wanna modify mass object which used to be family object in revit.I just wanna know if there is any way to transfer family type in revit to instance type in max.
Wed, Jun 1, 2011 at 2:01:15 AM | is there any way to transfer family object to instance object or something like
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
You mean, you want to create stuff like furniture in revit, and then export it to max, and then check if you can do some adjustments?
You could export those furniture as a separate file via fbx format, and instance them INSIDE max (with some plugins or with mrscatter or vrscatter).
On the other hand, if you need complex curtain walls exported into revit, then you need to export into max (link manager), reassign some materials, and clean up some mesh with too high polycount.
Wed, Jun 1, 2011 at 7:10:55 AM | is there any way to transfer family object to instance object or something like
gates1412
That's right. But the problem is that I find it's easy to set up the architecture scene in revit rather than in max cuz you could view objects by levels and place them accurately.
As I have already set up the major scene in revit . I wanna continue my work in max with the ablity to tweak mass object derive from family in revit .
And I heard that fbx has already support instance export. So I Just wanna know if there is anyway to set up workflow like this.
Family Object not displaying properly
Tue, Dec 4, 2012 at 11:32:10 AM
Change Default Family Category Model Object Styles
Thu, Jun 18, 2009 at 4:23:45 PM
Create Roof Family Object
Mon, Nov 21, 2005 at 7:10:42 PM
put object ID field in the properties palette in the family editor
Mon, Oct 17, 2011 at 12:02:32 PM
Object Style not showing unless object highlighted
Thu, Jun 8, 2017 at 3:29:24 AM
Page generation time: 2.6356
