8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Dims
22 Posts No Rating |
I have a site plan that is to big to fit on a A3 sheet (i don't won't to A2 or A1 sheets) that's not the problem, the problem is i have a set-back dimension and ever time i use a crop region and pull it over the dim. it disappears!! anyway of getting it to stay???
Shanzie
This was a change to revit they made in version 5 or 6 which really annoyed me, you used to be able to have dimensions outside of the crop region, now you can't.
You'll need to extend the crop region so it displays and use a white filled region to hide the unwanted information...
DIMENSIONS |
Fri, Jan 23, 2004 at 1:31:28 PM
Dims |
Tue, Jul 10, 2012 at 4:41:30 PM
Eq Dims |
Tue, May 1, 2012 at 2:33:20 PM
11
Can't read "Temp. Dims", too small?, change the size! |
Fri, Aug 17, 2012 at 5:19:26 AM
library part adjusts without guided dims or reference planes |
Sun, Dec 13, 2015 at 7:19:28 PM
