Forums >> Community >> Newbies >> Cost of a simple rendering
Mon, May 30, 2011 at 10:39:26 PM | Cost of a simple rendering
Joses8112
Hey guys,
How much will you charge for a rendering like this, very simple, first job after learning revit, Thanks
Tue, May 31, 2011 at 7:09:00 PM | Cost of a simple rendering
thetabest
thetabest Avatar
3 Stars: 2 Votes
Depends on the size of the project in $$.  I'm assuming you mean how much YOU should charge your client, I recommend taking the time it took you to create said rendering, including the computer hours (i.e.- if it is rendering, then you are still working, even if you are home in bed).  Charge your highest billing rate, and perhaps add a couple percent for padding and negotiation wiggle room should you end up needing it... If this is too high then you'll have to come down, but unfortunately, there isn't any given price table, etc.
As to me, if I had to make that model, the rendering would be a small cost eaten up by the budget of the project, i.e.- pad your budget to include the wow factor, because you WILL want to render / screen capture marketing material, to show off your whares and abilities.
Now for my honest guess, perhaps $150 to $200, at the high end, I personally wouldn't pay more if I were the client, and that is the bottom line, whatever amount you specify, the client has to be able to A) have the money and B) Be willing to spend the money.
GL
Trent Best
Best Systems
the.tabest@gmail.com
Tue, May 31, 2011 at 11:03:30 PM | Cost of a simple rendering
Joses8112
Thanks for your response,
As you can see this was a very simple rendering my client need it, nothing really fancy.
This is my first job and I really dont know how much to charge him, Your are saying that no more than $200, and I kind of agree with you, I spend aprox 5 hours.
So a $30/hour rate sounds good for you.
Thanks for your response. and any other suggestions are very welcome.
Wed, Jun 1, 2011 at 1:00:30 PM | Cost of a simple rendering
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Very hard to say.  Our firm doesn't bill so rigidly.  If our clients ask, or we feel we need to impress them, we'll give them a 500MB walkthrough video.  It boils down to hours spent on the project though.  If I'm sitting at my computer watching a render render for 1/2 an hour... well, I bill at close to 200 I think, so, that's 100 dollars.  But it's just general time spent on the project.  Renders are part of the job, not something extra any more.
Edited on: Wed, Jun 1, 2011 at 1:01:39 PM
Wed, Jun 1, 2011 at 2:45:56 PM | Cost of a simple rendering
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
for client renders just to get a feel for the context of the project I give as freebies. Anything done for marketing materials for clients is billed at an hourly rate tyipically becuase they involve physical materials, lighting and compositing. If you do not have a graphics billing rate just use your production rate.
Wed, Jun 1, 2011 at 5:36:42 PM | Cost of a simple rendering
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
My opinion
Rendering used to be a special skill only a few could do it, either the hand renders (artists) or the skilled 3Dmaxers who specialize in 'exotic' software that most of us never learned to use, so they could get away with billing high.  (supply and damand)
Now things have changed, with Revit anyone can render with practice and the bonus is you are already building the building so you only have to hit the render button (with a little extra work to get the materials and lighting etc.. right)  But again it doesn't take an extra skill set or software to do so.  I can work on the file on one machine and have it render on another machine so there isn't any extra work involved, I tend to build models as I would like to see them so my materials and lights are already correct so pushing a button is no extra charge.  I must admit, I do find myself tinkering with Renders a little too much to get them jussssst right, but because of Revit I have the extra time to tinker with renderings.
Revit is changing this industry, some are able to do more work because of it and some are losing a specialty skill because of it.  If you can get a few extra bucks on the side, I would bill at an hourly rate, what do you think your time is worth and go from there.
As alabaster says, marketing is a different story.
Edit...
But to eat my words a little, there are some very talaneted users that do mix it up with Revit, photoshop, 3Ds and some other softwares that can make some mind blowing renders that I will never be able to come close to.  Revit has just brought me a new skill set that I found easy to use.
Edited on: Wed, Jun 1, 2011 at 5:58:42 PM
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
Mon, Sep 30, 2024 at 10:07:14 AM | Cost of a simple rendering
daimmalik
The cost of a simple rendering can vary based on several factors, including the complexity of the design, the resolution, and the rendering software used. Here are some general price ranges:
  1. Basic Renderings: For simple 2D or 3D renderings, such as architectural floor plans or product prototypes, the cost can range from $100 to $500 per image. These renderings typically have minimal details and lower resolution requirements. Know more about Basic Renderings from cardfusions.com.
  2. Mid-Range Renderings: More detailed renderings, such as 3D models with texture, lighting, and moderate complexity, usually cost around $500 to $2,000. This type of rendering is often used for marketing purposes or client presentations.
  3. High-End Renderings: For photorealistic or highly detailed renderings that require complex textures, environments, and post-production work, prices can start at $2,000 and go up to $10,000 or more per rendering. These are typically used in high-budget projects like film production, video games, or luxury real estate.
Keep in mind that these costs are approximate and can vary by location, the expertise of the designer, and the rendering software. Software like Blender or SketchUp is commonly used for simpler projects, while more complex renderings may require advanced tools like Autodesk 3ds Max or V-Ray.
Wed, Dec 18, 2024 at 5:59:55 AM | Cost of a simple rendering
geriok
  • Time-Based Pricing: You correctly emphasize the importance of accounting for all the time invested, including rendering time. This is a fair and transparent method.
  • High Billing Rate: Charging your highest rate ensures you're compensated for your expertise and experience. emerald chatjavascript:mctmp(0);
  • Padding and Negotiation: Including a buffer allows for unexpected challenges and provides flexibility during negotiations.
Wed, Dec 18, 2024 at 6:02:21 AM | Cost of a simple rendering
geriok
Edited on: Wed, Dec 18, 2024 at 12:03:56 AM
I want to know how can I calculate the total cost with revit???
Sun, Mar 31, 2013 at 12:02:26 PM
Cost Estimating Software for Revit 2010
Fri, Jul 16, 2010 at 9:54:04 AM
total cost
Mon, Jan 17, 2005 at 5:35:00 AM
Material cost per sq ft formula
Mon, Sep 21, 2009 at 9:06:24 AM
preliminary cost estimates
Sat, Feb 27, 2010 at 7:24:14 PM
Page generation time: 0.5710
