Forums >> General Discussion >> Revit Project Management >> Which Template does have Brick and CMU over MTL Stud.
Mon, May 30, 2011 at 10:13:31 AM | Which Template does have Brick and CMU over MTL Stud.
kbral03
Im reading the Eric Wing book, Revit Architecture 2010: No Experience Required, im from dominican republic and i cant find the Brick and CMU on MTL Stud wall in any template, i downloaded many templates from autodesk as Uk, Canada, Polish etc but i cant find the template that does have this wall, my default template is named: DefaultESPESP, can anyone tell me which template does have this specific wall?
Mon, May 30, 2011 at 11:10:30 AM | Which Template does have Brick and CMU over MTL Stud.
It really doesn't matter if that wall type exists or not.  Simply create a wall type like that and use it.
Mon, May 30, 2011 at 11:42:10 AM | Which Template does have Brick and CMU over MTL Stud.
kbral03
Its a so complicated wall to be reproduced, if it was simple i would have already created it, however im starting at revit, and i dont have that great knowledgement of creating my own wall or families ( I know walls are easy but this one isnt) i wud be grateful if someone could attach the file here, thanks for all, Kbral
Mon, May 30, 2011 at 11:44:29 AM | Which Template does have Brick and CMU over MTL Stud.
kbral03
If you dont know where is your default template search it at : C:\Program Data\Autodesk\Metric Template\ Default....rte
Edited on: Mon, May 30, 2011 at 11:45:17 AM
Tue, May 31, 2011 at 7:46:38 AM | Which Template does have Brick and CMU over MTL Stud.
There is no such template for you to find or download.  Walls are system family and there is no template.  You have wall types in the project template you use when you start your project.  To create a new wall type, you modify one of your basic walls, duplicating it to create a new type, then add-subtract materials as you need.
I do not have the book you are talking about but I can guarantee you that there is no project template that has a really complicated wall type in it.   All project templates have simple basic walls.
I suggest you start by using one of these simple walls, then learn how to modify it.
Thu, Jul 14, 2011 at 9:24:44 AM | Which Template does have Brick and CMU over MTL Stud.
standeman
The Brick and CMU on MTL Stud wall you refer to can be found in the US Imperial Template (default.rte). If this template is not installed on your system, go to Control Panel - Programs & Features (Win 7), select your Revit program and then click Uninstall/Change. In the Revit window that appears, click Add or Remove Features and then place a tick next to US Metric. This will install the template.
Once installed, start a new project using this template and you will be able to draw walls of the type Brick and CMU on MTL Stud.
You can then, of course, copy this wall and paste it into whatever project you are working on (even if it is based on a different template).
Good luck.
Fri, Jul 15, 2011 at 3:38:08 AM | Which Template does have Brick and CMU over MTL Stud.
standeman
Should have added that another, possibly easier, way is to download the datasets from the books companion website. These will all have the said wall available for use.
Compound Walls & Finishes stopping at specific Heights
Wed, Nov 8, 2006 at 11:51:04 AM
CMU + brick wall- brick is NOT bearing
Tue, Dec 22, 2009 at 3:16:30 PM
Hello Newbie here, brick on brick on cmu wall type doesn't show up
Thu, Jan 27, 2011 at 1:06:15 PM
Wall Footing on Walls w/ Modified Base Extension
Wed, Nov 20, 2013 at 5:27:16 PM
Wall clean-up
Fri, Nov 21, 2008 at 3:21:12 PM
Page generation time: 0.3797
