Forums >> Revit Building >> Technical Support >> Beam Tagging
Mon, May 30, 2011 at 2:12:13 AM | Beam Tagging
ShawnH1
1 Stars: 1 Votes
Howdy all, I have uploaded the new 2012 version of Revit Architecture and all seems to be good apart from the tagging aspect of structural beams. First noticed that when I tried to load a timber beam from the International Library, it is automatically 'Analytical'. This makes it impossible to edit the family or to mark it in the properties display. Also I can't find and analytical annotation mark for it in any library. Any thoughts or ideas would be greatly appreciated.
Cheers
Shawn
Mon, Jun 6, 2011 at 11:51:47 AM | Beam Tagging
emgeeo
3.5 Stars: 7 Votes
What do you mean by 'Automatically Analytical'?
Do you mean to say that it is a single thick line?  Structural beams display as single lines in Coarse views.  If you over-ride the category in VV to display as Fine (you can over-ride individual categories and not the whole view) it should show up as a beam with width.
As for the tag, you just need to load a structural beam tag.  If there isn't one out-of-the-box, you can create it very simply.
Start with any annotations family template.
Change the category to structural framing.
Create a Label to read the Type Name.
Make sense?
Cheers.
concrete beam
Mon, Apr 7, 2014 at 12:27:08 PM
Issues with Beam Systems and Tagging Joists
Mon, Feb 25, 2008 at 8:42:09 AM
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:16 AM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:48 AM
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:36 PM
Page generation time: 1.3838
