Forums >> Community >> Newbies >> Sphere Mass - Changing the mass into a roof
Sun, May 29, 2011 at 1:18:48 AM | Sphere Mass - Changing the mass into a roof
DSArchitect
Hi everyone
I am having a problem creating a spherical roof for a planeterium design I am currently working on, and would appreciate any help!! :-) I am also fairly new and inexperienced with Revit.
I am currently using Revit 2011, and started the process by creating an in-place mass (I also did this by creating a new family, and then loading the family into the project). I simply created a circle, then created a solid form, and then to have the top half, selected the other half, and created a void form.
At this point I have half a sphere, however whatever I do, I cant seem to change this solid spherical mass into a hollow roof.
I hope I have given enough informaiton, and would really appreciate any help anyone can give me. Thanks you.
DS
Sun, May 29, 2011 at 5:18:54 AM | Sphere Mass - Changing the mass into a roof
4 Stars: 205 Votes
You can create directly in your project an "In-Place" family (Home > Component > Model In-place) in a "Roof" category with the material/texture you want.
Put some images so we can see what are you talking about.
Sun, May 29, 2011 at 8:33:19 AM | Sphere Mass - Changing the mass into a roof
DSArchitect
Thank you Typhoon
The image you attatched is exactly what I need, however I am unsure how to create the hollow sphere following your instructions above. I have been able to create a half sphere using the model In-place, Roof catergory, however the sphere is still solid.
If possible, could you tell me the quickest method to create the sphere, as the way I am currently doing it seems quite difficult, and isnt working. My current process is as follows:
1) Home > Model in - place > Roof Category2) Model Lines > Lines > Draw half semi-circle (within Level 1 Floor Plan) 3) Home > Revolve > Specify Boudary and Axis Lines4) Click the tick, and then finish model
Thank you again for your help, and time!
Regards DS
Sun, May 29, 2011 at 8:47:34 AM | Sphere Mass - Changing the mass into a roof
4 Stars: 205 Votes
Just sketch that with the thickness you want like you can see in my first image...
Hope this help
Sun, May 29, 2011 at 9:20:16 AM | Sphere Mass - Changing the mass into a roof
DSArchitect
Awesome. Thank you very much for the help Typhoon! :-)
Regards DS
Tue, Apr 16, 2013 at 8:25:38 AM | Sphere Mass - Changing the mass into a roof
adictedi
Yeah, there is a topic for how to create a HEMISPHERE in revit .. what do you know. A stupid HEMIPSHERE!!!
Man, Revit has the modelling capabilities of .. gtalk. You can actually model more stuff there.
Edited on: Tue, Apr 16, 2013 at 8:59:35 AM
Trying to void a spherical mass in 2012
Wed, May 18, 2011 at 1:22:23 PM
Reverse the face of mass for roofing
Sun, Dec 14, 2014 at 12:21:36 AM
Can't Cut It!!!
Mon, Nov 21, 2011 at 2:10:56 PM
Mass Floors with a Minimum Height/Clearance
Wed, Apr 18, 2012 at 5:25:50 AM
Chaning mass objects
Fri, May 8, 2009 at 3:41:08 AM
Page generation time: 1.3448
