11 Users Online (9 Members):
Forums >> Revit Systems >> Technical Support >> not enough room to place the required fittings
167 Posts No Rating |
So far so good, however occasionally in my HVAC plan when I try to attach a duct to a diffuser I get this message
There was not enough room to place the required fittings. Consider increasing the length of the segments, or moving them farther apart to generate a solution.
I can't seem to find an answer. i have attached a file of a current example. I have more than enough length for my duct line. Any help would be appreciated
Trevor
Using Revit Architecture 2012 |
I think what is in question here is the distance that the duct you are placing is above the register, so that a comfortable turn can be made down to the register. This often happens to me in low headroom situations so I make a special fitting to make the connection.
Fittings assigned to room outside the room area? |
Mon, Nov 19, 2007 at 10:43:47 AM
Room deleted but said still remain |
Sat, Dec 12, 2015 at 1:01:24 PM
Labeling/Schedule Piping per Room Location |
Mon, Jun 23, 2014 at 6:54:45 AM
how to create a room via room schedule first and then place it in the model |
Thu, Feb 21, 2008 at 10:34:06 AM
Duct Fittings showing halftone |
Thu, Aug 11, 2022 at 1:49:20 AM
