19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Monolithic Stair Question
2 Posts No Rating |
I am spinning my wheels to create a monolithic stair with triangular corner segments (overall shape like a trapezoid). Any suggestions?
do a sweep
This is easy and you don't need a sweep. Just sketch your treads and boundry in that shape.
Read this in your HELP: Creating Stairs by Sketching Boundary and Riser Lines
2 Posts No Rating |
WWHub - I like your suggestion but am struggling to find the thread you mentioned. Can you walk me through the process? I keep getting a grumpy Revit message that my stair must have more than 2 boundary lines.
18 Posts No Rating |
I think one way to create the pyramidal stair is from WWHub.
I created the pyramidal stair with 3 stairs with different shapes, which pointing to the top of the pyramid (see attached snapshot). However, you have to be aware on the stair corner (or junction / collision).
Hope it helps.
Search your HELP using stair as your search word. You will see the Creating Stairs by Sketching Boundary and Riser Lines listed in the search results.
CAN'T MAKE MONOLITHIC STAIR |
Fri, Feb 5, 2016 at 10:16:18 AM
13
Monolithic Stair with Stringer |
Wed, Aug 5, 2009 at 10:43:24 AM
Curved monolithic stair problem |
Thu, Mar 11, 2010 at 2:33:31 PM
Monolithic stair - large construction height error |
Thu, Oct 13, 2011 at 12:10:33 PM
Monolithic stair PROBLEM |
Sat, Feb 9, 2013 at 8:14:32 AM
