Forums >> Revit Structure >> Technical Support >> HELP!Material for imported Familys.
Tue, May 24, 2011 at 6:40:34 PM | HELP!Material for imported Familys.
MDoohan
I have downloaded vehicles and have found that when loaded into the Project they have there materials. as you would expect. but when i rendeer them the viechles tend to lose there materials and turn gray.
Any help is apreciated
Thanx
Tue, May 24, 2011 at 7:20:29 PM | HELP!Material for imported Familys.
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Hi -- I saw your message in the chat room, missed it though.  The problem is that when you import a family into your project, it's going to bring in new materials, and it's also going to use materials in your own library if there are duplicates in the naming.  So if you have a material called "Paint, Metallic Red", and your car family also has "Paint, Metallic Red" your project wins, and if your material is a default gray, the car is going to render that way.
Many default materials do not have their render settings set yet, even if they having a shading color.  So it can be deceptive.  Soooo, if you want to know what the materials of your car are, you might open up the family, and check out the different pieces.  Then make sure to go back to your project and modify those materials with a real render material.
Also, some family makers are SMART, and add a naming convention to their models, like LANDCRUISER_Tires, LANDCRUISER_Windshield, and so all the materials of an imported model are unique, and grouped together in the materials manager.  See if that's the case with yours.
Wed, May 25, 2011 at 4:18:34 PM | HELP!Material for imported Familys.
MDoohan
Thanks ill have a hack at it today.
i thought this would be the issue as im new to revit. im just being taught and have more of a solidwork and inventor background. haha.
Books on making revit familys
Thu, Feb 23, 2006 at 10:06:56 PM
How do you add an imported material to Revit's material library ?
Mon, Aug 16, 2010 at 8:06:17 AM
Massing - Applying Materials to Imported Geometry from Rhino-HELP!
Sat, Dec 10, 2011 at 6:30:09 AM
How do I ad a material to an imported family ?
Thu, Dec 26, 2013 at 10:06:17 PM
please help- tried everything to get objects to accept material...
Thu, Apr 16, 2009 at 12:45:04 AM
Page generation time: 1.5425
