Forums >> Revit Building >> Technical Support >> Shear Wall Length
Tue, May 24, 2011 at 2:09:40 PM | Shear Wall Length
TONY121
I have modified the standard wall tag to represent shear wall location and type however I want to be able to show the length of the shear wall as well. I can not seem to figure out how to get the tag to show the length of the wall. I am only having this problem with shear walls that are actually the full length of a wall. If I create parts within a wall the part tag will represent the length of the specified shear wall.
Within in the part tag family editor there already is a "length" label which allows me to do this however in the standard wall tag there is not "length" lable. If I create a shared parameter and apply it to the tag it does not show the length of a wall when loaded into a project. How can I add that label the the wall tag family category or assign it to automatically popluate the tag with the wall length?
Tue, May 24, 2011 at 5:00:45 PM | Shear Wall Length
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
 I've not uploaded this annotation, as I have not worked out all the bugs and added the features that I would like. Take a look maybe you can improve on it.
Shear Wall Symbol
Thu, Oct 22, 2009 at 10:29:41 AM
Shear wall tag with label that reads wall length
Fri, Oct 21, 2011 at 5:57:35 PM
Shear studs on Steel Beam Family
Wed, Feb 26, 2025 at 5:57:33 AM
Shear Wall Calculations using Revit !!
Fri, Nov 21, 2008 at 4:03:36 AM
wall tags - shear wall tag on exterior (sheathed) side of wall?
Tue, May 26, 2009 at 9:55:16 AM
Page generation time: 3.0071
