Forums >> Revit Structure >> Technical Support >> 2 Thickened Slab Edges in ONE Foundation Slab
Tue, May 24, 2011 at 11:12:39 AM | 2 Thickened Slab Edges in ONE Foundation Slab
AdamU
I am trying to add thickened edge condition to a slab on grade (foundation slab). I have created 2 profiles Types in the same Thickened Edge family. I apply Type 1 thickened edge to the floor edge and I exit of the active command. It works as it should. Then I want to choose a different thickened edge profile (Type 2) and apply it to a different edge of the SAME floor outline. What happens is that the Type 1 profile created before now changes to Type 2. Question: Is it only possible to have a single thickened edge profile per ONE floor outline? I’m using REVIT Structure 2011 though it should apply to Architecture 2011 as well. Thanks!
Mon, Jun 6, 2011 at 12:09:29 PM | 2 Thickened Slab Edges in ONE Foundation Slab
emgeeo
3.5 Stars: 7 Votes
I have not had this problem with 2011.  Not sure what to tell you.
Bump.
Mon, Jun 6, 2011 at 12:13:35 PM | 2 Thickened Slab Edges in ONE Foundation Slab
It sounds like you are only modifying the picked profile for the slab edge type.  You need a new slab edge type with this second profile.   Understand?
Rebar in a thickened slab Revit 2012
Thu, Dec 29, 2011 at 6:40:29 AM
Modeling thickened slab strip under bearing walls
Thu, Feb 5, 2015 at 1:13:00 PM
Slab Edges
Fri, Jan 29, 2016 at 7:37:23 AM
Thickened Slab Not Cutting Floor Line Out
Wed, Dec 28, 2011 at 7:54:13 AM
Thickened slab appearance
Fri, Jun 8, 2012 at 10:43:23 AM
Page generation time: 0.1583
