Forums >> Revit Building >> Technical Support >> View Rotation
Tue, May 24, 2011 at 10:35:18 AM | View Rotation
mfadel20
I have an issue with my second floor plan view being slightly rotated.  I am not sure what angle the view is rotated but it's very slight (where would this information be displayed?).  My "UCS" is aligned but the view is askew, which means that when I try to rotate the crop region boundary (as I'm guessing this is how is got skewed to begin with), I have to know the angle that the crop region is at, so that I can type amount that into the command.  Thanks!
Tue, May 24, 2011 at 10:46:51 AM | View Rotation
You really don't want to do it that way because of unit problems.  Instead, try this.
  1. Rotate the view first so that it is not a small angle.
  2. Draw a horizontal detail line across something in your view that should be horizontal
  3. Click on the boundry and pick rotate
  4. Move the rotation center to the intersection of your detail line and component that should be horizontal
  5. Select the rotation from the horizontal to the component.
DONE
Tue, May 24, 2011 at 11:06:15 AM | View Rotation
thetabest
thetabest Avatar
3 Stars: 2 Votes
Or press F1 then type "rotating view"
Trent Best
Best Systems
the.tabest@gmail.com
Tue, May 24, 2011 at 1:20:50 PM | View Rotation
mfadel20
Thank you guys!  I was having some touble but eventually got it to work!
View Rotation on Sheet
Thu, Jan 18, 2007 at 10:12:38 AM
View Rotation on a Sheet
Tue, Feb 14, 2012 at 1:32:37 AM
view label rotation plan view
Tue, Dec 30, 2014 at 11:17:50 AM
Tue, Oct 27, 2009 at 12:35:35 AM
Slight rotation in a single view
Wed, Mar 22, 2017 at 12:43:12 PM
Page generation time: 2.0136
