13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Re-ordering the sheet index, hurry need help!!!!!!
10 Posts No Rating |
Ok, ive searched no luck or good explanations...
Plain in simple, in my sheet index, i need ED to come before E, in my electrical part of sheet index...
how do i go about re ordering this... thanks
Edited on: Mon, May 23, 2011 at 10:40:30 AM
Edited on: Mon, May 23, 2011 at 10:41:23 AM
Add a new parameter to your sheets in the project parameters called sort order. Add that filed in your schedule and sort by it, then hide the column
You must not have looked very hard because the answer is listed below in a similar thread as well..
Edited on: Mon, May 23, 2011 at 10:45:51 AM
when i go to Project parameters, there is no choice under add, of sort order....
I'm sorry, I said that badly. you can add a shared project parameter, or in your sheet scheuld, you can just add a parameter there. Just goto your schedule and under fields, add a parameter there.
Links to each sheet in sheet index |
Sun, Aug 21, 2016 at 11:06:31 AM
sort sheet index by discipline |
Sun, Oct 11, 2020 at 12:55:35 AM
Sheet / Drawing Index / List Check Box |
Thu, Dec 18, 2008 at 8:48:15 AM
Index of details on a sheet |
Wed, Aug 27, 2014 at 3:40:38 PM
Combine multiple sheets into a single PDF file per THE SHEET INDEX |
Fri, Jul 31, 2015 at 3:00:27 PM
