12 Users Online (10 Members):
Forums >> Revit Structure >> Technical Support >> Creating a Pile Schedule
4 Posts No Rating |
Hi, I'm trying to create a pile schedule with Pile Numbers and co-ordinates for all piles in our project.
I have the extensions for Revit and and excitech tool kit. I'm using Revit Structure 2011.
I used the element positioning extension to generate tags for the piles but it only tagged the caps not the individual piles. Do I need to use seperate piles and caps when creating the model? I just used the pile caps with piles in the library out of the box.
Make sense?
Cheers
Adam.
Always read the similar threads shown below when you post. Here is a possible answer:
Check out the extensions availble with your subscription . I thik this is the one you are looking for:
http://www.extensions4revit.com/n/e4r/856/60
4 Posts No Rating |
Yeah I did have a quick look through the forums but nothing seemed to answer my specific question with regards to separating the piles from the caps. The answer to which is No. It's just a case of making the right parameters shared through the nested families.
I now have another question though, is it possible to add a pile cut off parameter? I'd quite like one in the pile schedule/table... any guidance on creating something like that?
Cheers.
Pile cut-off Level, Adding Parameter to Pile Family ?????? |
Tue, Oct 16, 2012 at 2:39:10 PM
Elevation parameter in pile-schedule |
Tue, Feb 19, 2013 at 4:28:38 AM
Pile Schedule / Record |
Mon, Apr 28, 2008 at 1:48:47 PM
Pile Caps - Schedules Vs. Takeoffs |
Mon, Nov 5, 2012 at 10:42:33 AM
Pile Cut off in Schedule |
Mon, Oct 8, 2012 at 2:40:03 PM
