Forums >> Revit Building >> Technical Support >> nudging or moving the entire piping system upward vertically
Thu, May 19, 2011 at 9:43:42 PM | nudging or moving the entire piping system upward vertically
mervzkiey
we recently made an entire fire protection system and send it back to our client. Then later on they re-send the package and told us that they have moved the architectural dwg (link file) upward by 4 feet for the reason that we don't know.so they have told us to do the same thing in the fire protection system.. So here's what we've encountered, we thought that it would be as easy as selecting it all and moving it up by 4 feet so as to coordinate it with the architectural dwg. but rather, there were problems like things will be deleted, etc.. is there a proper way to move it all up? we already unpinned it all, included the ceilings(not part of the link file, we did this in the fire pro file coz they didnt provide it) in moving coz all sprinklers are hosted.. anyone who knows?
Fri, May 20, 2011 at 7:26:15 AM | nudging or moving the entire piping system upward vertically
Are you saying you didn't use the linked file's levels?  That is the purpose of copy monitor.  When the linked file's levels move, you just accept the change and your done.
If you didn't do the above, look into relocating your project.  You can read about that in your HELP.  That will not create the problems you are having.
Edited on: Fri, May 20, 2011 at 7:27:50 AM
Moving an entire plan
Mon, Oct 29, 2012 at 7:31:51 AM
Red lines around piping, System types
Mon, Jun 8, 2009 at 4:45:43 PM
Adding materials to piping systems
Mon, Oct 12, 2009 at 4:07:42 PM
Piping System Families
Mon, Dec 3, 2012 at 3:46:31 PM
help with a Filter issue in VG
Wed, Sep 30, 2009 at 12:54:37 PM
Page generation time: 3.6070
