Forums >> Revit Building >> Technical Support >> Can't get fascia heights to match
Thu, May 19, 2011 at 9:06:50 AM | Can't get fascia heights to match
phishyman2
I am doing an addition to a home. The existing roof is a 8/12 hip. I am adding a shed/hip roof to the corner of the house at the addition. The short side of the addition is 8/12, which matched the existing roof. The long side is 2/12. When I create the roof the fascia board is shorter then the existing roof fascia. I am able to align the bottom of the fascia boards, but can't get the height to match. Any ideas?
Thu, May 19, 2011 at 10:55:36 AM | Can't get fascia heights to match
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
This is a problem with the geometry of the roof. If the narrow side is 8:12, and the long side is 2:12 the roof overhangs must be a different length in order to match up.
Thu, May 19, 2011 at 4:57:15 PM | Can't get fascia heights to match
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Hey there.  Roofs are frustrating stuff.
The problem you're having is that you have your roofs set to "plumb cut" which slices through them vertically.  This is going to be a different depth for any slope of roof, as I exaggerate in the attached pic.
What you can do, however, is set the rafter cut to "two cut plumb" with a Fascia depth equal to or less than the width of your roof structure, and it'll match all the way around.  Hope that helps.
Fascia on Sloped Glazing
Tue, Aug 23, 2005 at 11:58:53 AM
Why do all my Wall Heights default to 20'-0" !!
Wed, Apr 26, 2006 at 4:31:21 PM
More fascia woes.
Sat, Sep 17, 2005 at 1:29:00 AM
Roof Fascia Doesnt Render
Fri, Jul 14, 2006 at 5:15:34 PM
Frustrating Fascia
Sat, Jan 7, 2006 at 10:52:05 PM
Page generation time: 9.2073
