Forums >> Revit Building >> Technical Support >> Structural Members not showing up in any view- Revit Arch 2011
Thu, May 19, 2011 at 4:24:43 AM | Structural Members not showing up in any view- Revit Arch 2011
cmgilman
My model was working fine, but all of a sudden structural members are not visible in any view- trusses, beams, and columns will not show up in plan, section, or 3d. I have the detail level set to fine, and made sure that everything was selected in visibility graphics override. HEEELPPP!
Thu, May 19, 2011 at 7:09:45 AM | Structural Members not showing up in any view- Revit Arch 2011
Check your Discipline settings in the view properties and try coordination.
Is this a linked model?
Did you check your VG settings - click the show all so that you can see structural properties.
Thu, May 19, 2011 at 12:11:08 PM | Structural Members not showing up in any view- Revit Arch 2011
cmgilman
Thank you for your reply! Unfortunately, none of those solutions worked- not view properties, vg, discipline or even phase properties and not a linked model. The structural systems are still in the model, because if I drag my mouse over the model, they highlight, but once I deselect, they disappear.
Any other suggestions? I have attached a screenshot in case that helps. This is a major problem that I need resolved ASAP- Big deadline. Thanks!
Revit 2012 Truss System (framing members not showing)
Wed, May 9, 2012 at 9:25:33 AM
Structural Elements in Revit Arch not showing correctly
Thu, Apr 9, 2009 at 5:38:27 PM
Sloping Structural Members
Sun, Jan 9, 2005 at 5:32:40 PM
Curved structural members??
Tue, Apr 6, 2010 at 11:35:56 AM
Structural Members in Revit
Tue, Jan 20, 2009 at 6:58:51 PM
Page generation time: 6.4553
