10 Users Online (8 Members):
Forums >> Revit Structure >> Tips & Tricks >> Open Bond
3 Posts No Rating |
I need to make an open bond wall. Im trying to figure out what is the easiest way to make it. a new family, edit profile, etc.
any suguestions would be appreciated.
I would probably do an in-place void family for each wall elevation. One per wall. See this thread:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=23757
That void cut can be full depth so that the pattern shows from both sides.
Edited on: Thu, May 19, 2011 at 6:38:20 AM
If this is going to be a free-standing wall of only masonry and you need to see the patten from both sides then i would use edit profile.
3 Posts No Rating |
i tired the 1st solution and the void was having a lot of problems cutting the plane.
i decided to just make a mass as a group and then array it along the wall. but that wasnt very editable and it bogged down my computer.
so i tried the second solution, and it looks great
Custom Running Bond Brick Pattern |
Fri, Aug 26, 2016 at 2:38:25 PM
4’ x 8’ running bond hatch. |
Thu, May 8, 2008 at 7:02:50 AM
A Rebar/ Bond Beam Family Question |
Mon, Nov 5, 2012 at 7:08:20 AM
Ceiling grid hatch |
Tue, Apr 30, 2013 at 2:23:08 PM
.pat file - running bond with angled tiles |
Thu, Mar 30, 2017 at 6:28:09 PM
