Forums >> Revit Building >> Technical Support >> Trouble Turning On/Off DWG link
Tue, May 17, 2011 at 10:08:20 PM | Trouble Turning On/Off DWG link
leothelionator
When I use the hide command to turn off a DWG link, I cannot get it back.  I use the Reveal Hidden Elements button to visually retrieve it, but it turns up missing.  So then, I check Visibility Graphic Overrides to make sure that the DWG link is checked on, but it still does not show up.  How can I retrieve my hidden dwg without having to re-insert the file?
Tue, May 17, 2011 at 10:17:03 PM | Trouble Turning On/Off DWG link
leothelionator
I think I figured it out.  The DWG is underneath my topography which is also turned off which would explain why it is not visible.  I thought I already took care of the wireframe display settings before I used the Reveal Hidden Elements command, but then I realized that you have to enable the wireframe while in the Reveal Hidden Elements command, not before.
Revit link dwg issues
Mon, Jul 1, 2013 at 8:09:19 AM
Link Cad issues
Tue, Aug 5, 2014 at 11:28:03 AM
import/link, manage links...
Tue, Apr 1, 2008 at 11:46:16 AM
Creating Turning Veins
Tue, Apr 21, 2015 at 6:29:38 PM
Revit Mass Family - DWG import - the "Link" checkbox grayed out... ?! HELP
Tue, Jan 9, 2007 at 5:34:28 AM
Page generation time: 4.0324
