27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Controlling Relative Spot Elevations
148 Posts No Rating |
Greeting. (RAC 2011)
I have seen several posts regarding similar questions, but none that have answered this specific one:I wish to modify the spot elevations to identify the insulation thickness on the roof, such that the roof drain reads "0" and all other elevations read "+XX" (above the drain).
I can get close, the relative setting will show the elevation relative to the current view (level). Please see attached image. But the bosses really want to see the elevation of the built-up roofing relative to the drain. Is this possible?
Ian Shafer
Principal Consultant
True North S&F Consultants |
Sure - as a dumb tag that you fill in.
... so the closest I can get is an elevation relative to the particular level? Bummer! (thanks)
Ian Shafer
Think out of the box...you already have your answer.
If you model the thickened roof like foam it should pick this up with a elevation tag. A lot of work though.
Topo surface points change from relative to absolute elevations [ 1 2 ] |
Thu, Apr 7, 2016 at 9:33:19 AM
15
spot elevation orientation in 3D view |
Tue, Aug 17, 2010 at 4:25:52 PM
more complex spot elevations |
Tue, Jan 23, 2018 at 7:48:21 AM
Setting a manual height for Spot Elevations in plan |
Wed, May 27, 2015 at 8:03:11 AM
Spot Elevation Relative to Floor |
Wed, Jun 5, 2013 at 6:53:59 AM
