Forums >> Revit Building >> Technical Support >> Offset roof by accident
Tue, May 17, 2011 at 10:59:36 AM | Offset roof by accident
juststarting
Hi, I am putting a tin roof on my house and for some reason the roof is offset and I can't fiqure out why. What I did was
·Created a roof
·Change the type to slope glazing
·Then I created a custom curtain wall using curtain wall panel.rft
·Loaded family (curtain wall )into my drawing
·Clicked on roof
·Edit type
·Construction
·Curtain panel value “custom curtain”
and well you can see the pics. It has a 4 1/2 offset and I can't find out why
Tue, May 17, 2011 at 11:18:44 AM | Offset roof by accident
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
change base level to one in the properties
Tue, May 17, 2011 at 12:10:30 PM | Offset roof by accident
juststarting
ok I tried that and got a error message. See pic
Tue, May 17, 2011 at 12:32:34 PM | Offset roof by accident
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
make a section through the building select the roof, move down
Tue, May 17, 2011 at 12:40:27 PM | Offset roof by accident
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
This is not just a roof, it's a curtail wall panel?  That's strange, but for corrugated roofing, I guess that can make sense.
My guess is that if you tab through, and select the -panel- itself, not the curtain system, you'll see that it has an offset in its properties.  Typically, a panel should be centered in a curtain wall.  So, select one of the planels, and look in properties, you might also go to "edit" type up there at the top of the properties box.
Tue, May 17, 2011 at 2:03:47 PM | Offset roof by accident
juststarting
Sad no luck yet. Wierd ain't it?
Tue, May 17, 2011 at 4:02:45 PM | Offset roof by accident
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
when you made the roof did you use sloped glazing?
Tue, May 17, 2011 at 4:12:34 PM | Offset roof by accident
itsmyalterego
4 Stars: 16 Votes
You might open up the panel family and see if it's drawn 4' 6" off center in that case
Tue, May 17, 2011 at 4:12:40 PM | Offset roof by accident
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I just looked back at your first post to find that it is a glazed roof, note the base level from one view to the next.
Tue, May 17, 2011 at 4:14:42 PM | Offset roof by accident
thetabest
thetabest Avatar
3 Stars: 2 Votes
Those warnings indicate that you have components which are cutting the roof you made, when you move it down, they need to go down too.  If you selected them, and the roof, and moved all as one, you should be good to go.  The tough part is getting them all.  To fascilitate this, turn your roof into a group, and as you find an object, add it to that group, until finally your able to move it down, once you have it in place, ungroup and purge.
Hope it works
Trent Best
Best Systems
the.tabest@gmail.com
Wed, May 18, 2011 at 1:11:42 PM | Offset roof by accident
#11
juststarting
Thanks for everyones  help. That part is fixed. I had deleted the roof several times and tried to create it again and that didn't work. This time I went in the project browser and deleted my custom curtain. It said removing 66 instance of it. So I reloaded it and it was flat on the wall. yeah!!!!
But, and there is all a but. It's still too long at the top. Weird looking.
Possible to specify the starting offset object?
Thu, Aug 29, 2013 at 1:47:59 PM
Roof Plate Offset
Thu, Jun 17, 2010 at 12:40:02 PM
Revit Roof Issue
Mon, Jun 25, 2012 at 11:28:59 AM
Roof Cutoff Level/Offset
Fri, Apr 2, 2010 at 5:09:24 AM
Roof offset from level, but why?
Sun, Apr 29, 2007 at 3:41:52 PM
Page generation time: 0.5950
