Forums >> Community >> The Studio >> new 2 revit
Wed, Nov 16, 2005 at 7:00:00 PM | new 2 revit
Brainstem
i'm trying to make a recessed fire extinguisher family cabinet and when i do a void extrusion it doesn't seem to remove the wall material. when i view it in "hidden" or "shaded w/edges" in a 3-D view it doesn't seem to look right. however in a wireframe setting it definitely subracted a portion of the wall. anyhow, i'm wondering if there's any way of getting around this? .b.
Thu, Nov 17, 2005 at 6:08:11 PM | RE: new 2 revit
eldados
eldados Avatar
4.5 Stars: 8 Votes
did you make sure you use the cut tools to tell the void what to cut? post a screeny...
Integrator
KarelCAD
Thu, Nov 17, 2005 at 8:20:40 PM | RE: new 2 revit
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
As eldad suggested. Be sure to use the cut geometry tool, select the void then the wall to tell the void to physically cut the wall.
Fri, Nov 18, 2005 at 10:51:28 AM | RE: new 2 revit
Brainstem
thanks a lot....didn't realize that tool was there nor how to properly utalize the void solid tool apparently.
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:39 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
We are looking for Revit Users [ 1 2 ]
Thu, Mar 31, 2011 at 5:15:24 PM
17
AutoCad vs Revit [ 1 2 ]
Thu, Aug 4, 2011 at 1:58:52 PM
16
Page generation time: 2.1149
