Forums >> Revit Building >> Technical Support >> Trying to void a spherical mass in 2012
Mon, May 16, 2011 at 7:26:07 PM | Trying to void a spherical mass in 2012
greg1970
Ok, Im at home and not in front of my computer but I'll try to explain this.
Im trying to void the bottom of a sphere - think magic 8 ball.  But the sphere wont void.
Here is what I am doing:
1. create a mass (solid) in place.
2. draw circle on level 3
3. create mass, pick sphere. Sphere is createdwith bisecting line, i dont do many spheres, i assume line is normal
4. draw rectangle on level 1
5. creat mass (void) - extrude until it intersects a bit of the bottom the sphere
6. complete operation.  nothing.  doesn't work, the bottom of the sphere is not voided.
I can do this same operation on a 2010 version of Revit and its works, just no my 2012.
Is there a toggle or option Im not aware or is 2012 different in some way?
Help is appreciated.
Tue, May 17, 2011 at 3:44:22 AM | Trying to void a spherical mass in 2012
4 Stars: 205 Votes
Just a question, did you used the "Cut Geometry" tool?
Tue, May 17, 2011 at 6:48:13 AM | Trying to void a spherical mass in 2012
greg1970
Yes, I did try the "cut geometry" tool.
Tue, May 17, 2011 at 1:19:07 PM | Trying to void a spherical mass in 2012
4 Stars: 205 Votes
Watch this: http://screencast.com/t/GWymHXqz
Tue, May 17, 2011 at 1:57:26 PM | Trying to void a spherical mass in 2012
That was interesting Ty .... you need to send this video to AutoDESK
Tue, May 17, 2011 at 3:23:04 PM | Trying to void a spherical mass in 2012
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I was able to reproudce this problem, but subsequently I've been able to fully cut a sphere several times with a couple of voids.  I don't know.  I've always been wary of Massing, and stick to the basic modeling tools, revolves, sweeps, etc.
Tue, May 17, 2011 at 6:48:14 PM | Trying to void a spherical mass in 2012
greg1970
thanks Typhoon.  I ended up just doing a revolve to accomplish the shape.  But I'll remember the advice.
Wed, May 18, 2011 at 1:22:23 PM | Trying to void a spherical mass in 2012
4 Stars: 205 Votes
OK, I solved the problem, watch the videos:
this is in "Conceptual Mass": http://screencast.com/t/pZb04ebm
and this is in "Project": http://screencast.com/t/7VsysVW5WI
Create the Sphere and the Void in a "Elevation view" and not ina "Plan View"
Sphere Mass - Changing the mass into a roof
Tue, Apr 16, 2013 at 8:25:38 AM
wall by face not being cut by void in mass
Wed, Jul 17, 2013 at 3:33:06 PM
Mass, radial wall by face, opening(void) problem!
Mon, Nov 11, 2013 at 12:51:10 PM
Void Mass Not Cutting Divided Surface Mass
Wed, Jan 31, 2018 at 10:19:21 AM
spherical background while accurendering
Thu, Sep 27, 2007 at 4:56:55 PM
Page generation time: 0.4395
