Forums >> General Discussion >> Revit Project Management >> voronoi surface pattern
Sun, May 15, 2011 at 9:50:05 PM | voronoi surface pattern
peerage
4.5 Stars: 2 Votes
Do you know if it is possible to create a voronoi surface pattern? or if one already exists. I want to create a facade system using a conceptual mass and divide the surface up using the surface patterning tool. This surface needs to be divided like a Voronoi Surface pattern, similar to this....
Sun, May 15, 2011 at 9:51:01 PM | voronoi surface pattern
peerage
4.5 Stars: 2 Votes
Any ideas??
Fri, Jun 24, 2011 at 1:51:43 PM | voronoi surface pattern
Bobbynic
I would just make the surface with walls and just use "edit profile" to cut out the pattern. This might work with a conceptual mass, but I am not entirely sure.
Fri, Jun 24, 2011 at 2:14:03 PM | voronoi surface pattern
No conceptual mass for me - way too much work!.... Model in place ...wall category with voids added in-place.
Surface pattern
Mon, Sep 10, 2007 at 11:18:01 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:00 PM
Surface pattern problem
Tue, May 18, 2010 at 9:15:56 AM
Surface pattern to Topo surface
Mon, Aug 19, 2013 at 10:50:10 PM
Page generation time: 0.7303
