22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Revit Family & Cad Dwg
5 Posts No Rating |
I found this rfa, to me this was imorted from autocad ... Well during the pass few days I have try converting the component or making into a revit family, but with no luck... where i can change the scale the column into different height 6'-0, 8'-0' ...since is a solid form? unfortunately i dont know what is the problem... can some one help me...
Can some point me to a website that explain how to modified the cad block?
Thanks
You can NEVER modify anything you import from cad, sketchup, and other cad format. end of question.
Once it is imported, it became dead.
The best advise I would give is to learn how to create it on your own, I never used imported object in my family as it polluted the revit model and its performance.
there are resources on the web to show you how to make families, and Autodesk has a "family guides" to download.
try searching it at the autodesk site.
good luck
torres- here's the way i do it.. i open a SEPARATE session of revit- (takes
twice as long to start up if you use the ribbon i know)- and then import
the DWG file into a mass element there.. get your import scale right
with black lines only.. then you can slice it and dice it and measure
it and even use the windows snipping tool and bring images over
to your project.. use DWGs AWAY from your revit project like
pchan says..
5 Posts No Rating |
Thanks!
Revit 2012 Titleblock Family Import Cad geometry not visible |
Thu, Dec 15, 2011 at 12:51:43 PM
Dwg to RFA and Materials. |
Sun, Feb 2, 2014 at 1:40:54 PM
how to create revit family from cad 3d drawing |
Tue, Apr 29, 2008 at 4:32:08 PM
3d cad dwg |
Mon, Feb 8, 2010 at 4:31:56 AM
Keep .dwg Layers when exporting .rvt to .dwgPlease |
Wed, Feb 24, 2016 at 9:27:59 AM
