Forums >> Revit Building >> Technical Support >> Cut & Pasting Question
Wed, Nov 16, 2005 at 4:42:25 PM | Cut & Pasting Question
arccodex1
3 Stars: 1 Votes
If I cut an object then I want to paste it in the same location it shows in red but I have to line up the object and paste. Isn't there a way to paste the object as shown? I tried the ESC key but that doesn't work. Post edited on 2005-11-16 16:59:44
Wed, Nov 16, 2005 at 4:44:53 PM | RE: Cut & Pasting Question
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use the paste aligned-->current view I've setup this as a shortcut PA
Wed, Nov 16, 2005 at 4:58:42 PM | RE: Cut & Pasting Question
arccodex1
3 Stars: 1 Votes
thanks Mr. Spot
Mon, Dec 11, 2006 at 1:49:38 PM | Cut & Pasting Question
pdmasonnz
I've the same symptoms when I have a shortcut setup for the "paste to current view". It will paste into the correct position in the view but will highlight the pasted objects and go into an edit mode to located them at a user selected base point. How can I accept the original location? Thanks.
Windows & cut planes
Fri, Aug 10, 2007 at 3:24:30 PM
Cut and pasting between revit models?
Wed, Apr 26, 2006 at 1:13:25 PM
STAIRS - Stringer & Handrail Cut
Mon, Nov 1, 2010 at 8:06:54 PM
Siteworks Cut & Fill
Wed, Jun 1, 2011 at 5:12:56 AM
Shadows & Cut Planes
Wed, Jun 15, 2011 at 12:24:13 AM
Page generation time: 0.5242
