Forums >> Revit Building >> Technical Support >> Schedules showing a DOT or CIRCLE for the Yes / No Parameter
Thu, May 12, 2011 at 1:33:10 PM | Schedules showing a DOT or CIRCLE for the Yes / No Parameter
iamian33
iamian33 Avatar
Greetings
RAC 2012
I have told that there is a way to represent the results of a Yes/No parameter in a (room or door) schedule as a DOT or CIRCLE.  I suspect that there is a specific font that I can use for these schedule cells ... does anyone know how to do this?
Ian Shafer
Principal Consultant
True North S&F Consultants
Thu, May 12, 2011 at 1:55:57 PM | Schedules showing a DOT or CIRCLE for the Yes / No Parameter
If you make a yes/no field, you get a check box..... I know - it doesn't look the same as the dots we used to use but visually it works.  You might want to register the option to change this in the AUGI wish-list area.
If it is not an automatic field, you can insert a text parameter and type Alt+0149 to get bullets •••.  NOTE: Size is contolled by font.
Thu, May 12, 2011 at 2:26:33 PM | Schedules showing a DOT or CIRCLE for the Yes / No Parameter
TKennedy
4 Stars: 8 Votes
What I have done to convert a Yes/No parameter to text is create a calculated value that reads 'if(Conn Plug, "X", "")', then I hide the 'Conn Plug' field. If 'Conn Plug' is checked then I get an X in the schedule. As WWHub said you can put a text bullet in the schedule, I don't know if there is a character for a circle.
Thu, May 12, 2011 at 3:43:59 PM | Schedules showing a DOT or CIRCLE for the Yes / No Parameter
iamian33
iamian33 Avatar
Thank you both for your responses.
I have the check boxes for user input.  But what I was hoping for was that the schedule, when on the sheet, would show a DOT or CIRCLE instead of YES or NO.
I thought that I had read somewhere that I could achieve this ... however a calculated value seems like a reasonable option.
Ian Shafer
Thu, May 12, 2011 at 4:15:14 PM | Schedules showing a DOT or CIRCLE for the Yes / No Parameter
iamian33
iamian33 Avatar
Ok, so I've got this working with the calculated value but if the answer to this statement:
if(F1 CONCRETE, "Alt+0149", "") .......... YES ==> Alt+0149
How do I get this expression to show the CHARMAP character in the schedule?
Ian Shafer
Fri, May 13, 2011 at 9:33:49 AM | Schedules showing a DOT or CIRCLE for the Yes / No Parameter
TKennedy
4 Stars: 8 Votes
Try entering the character elsewhere, then C&P into the formula.
Fri, May 13, 2011 at 10:52:47 AM | Schedules showing a DOT or CIRCLE for the Yes / No Parameter
iamian33
iamian33 Avatar
so simple ... works like a charm.  Thank you.
Ian Shafer
Fri, May 13, 2011 at 11:11:50 AM | Schedules showing a DOT or CIRCLE for the Yes / No Parameter
TKennedy
4 Stars: 8 Votes
No problem. I generally end up with at least two schedules when I need to do something like this, one that goes on the sheets with the Yes/No params hidden, and one with them visible that I actually work in.
Fri, May 13, 2011 at 11:19:49 AM | Schedules showing a DOT or CIRCLE for the Yes / No Parameter
iamian33
iamian33 Avatar
I'm using
in my schedules to humour myself
Ian Shafer
Fri, May 13, 2011 at 11:44:19 AM | Schedules showing a DOT or CIRCLE for the Yes / No Parameter
TKennedy
4 Stars: 8 Votes
Ha! Awesome.
Mon, Oct 30, 2017 at 7:02:47 AM | Schedules showing a DOT or CIRCLE for the Yes / No Parameter
zakazai
http://prosoftaec.blogspot.ae/2012/07/revit-schedules-with-graphic-yes-no.html
List of drawings - how can i add a circle or dot parameter related to the phases
Mon, May 18, 2015 at 2:07:30 PM
Howdy! I'm new!
Wed, Apr 14, 2010 at 1:29:56 PM
Custom leader arrowhead
Tue, Jan 27, 2009 at 1:34:05 PM
yes/no and if/then
Fri, Oct 17, 2014 at 1:58:37 PM
display edges and openings above the cutting plane in a dash dot dot linestyle
Thu, Mar 10, 2005 at 7:12:05 PM
Page generation time: 0.7929
