Forums >> Revit Building >> Technical Support >> Getting rid of material lines within walls
Mon, May 9, 2011 at 5:44:35 PM | Getting rid of material lines within walls
ALICEHER
Does anyone know how to get rid of the lines that represent the different materials of a wall? The attached image is of a (2) 2x6 wall with a 17 1/2" air gap. Currently the lines for the air gap are showing. Is there anyway I can modify the settings of the wall so they don't show up? I tried merging the regions, but all it did was combine the materials. I would like to keep the materials separate. (I'm using Revit 2012)
Thank you!
Tue, May 10, 2011 at 7:10:40 AM | Getting rid of material lines within walls
Each layer of the wall will be represented in medium & fine plan views.  You can use the line tool on these in each view and change them to invisible lines but this is only useful for a few instances..
Tue, May 10, 2011 at 10:08:28 AM | Getting rid of material lines within walls
TKennedy
4 Stars: 8 Votes
You should also be able to go to V/G and change the wall category to Coarse in the view.
Tue, May 10, 2011 at 10:51:54 AM | Getting rid of material lines within walls
coreed
coreed Avatar
4 Stars: 16 Votes
why not draw this as two seperate walls with 17 1/2" in between them?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, May 10, 2011 at 1:29:53 PM | Getting rid of material lines within walls
thetabest
thetabest Avatar
3 Stars: 2 Votes
Do the following:  select visibility graphics overrides for said view, then select the Cut Line Styles checkbox.  Then select the edit button, pops up a dialog box from which you can control the lineweight of each layer, based upon its number, i.e.- [1], [2], etc.
Oops, this is if you WANT to show the lines as different line weights, misread your question!
Edited on: Tue, May 10, 2011 at 1:31:51 PM
Trent Best
Best Systems
the.tabest@gmail.com
Decal Boarder and material scaling
Wed, Nov 27, 2013 at 1:37:16 PM
In shaded View walls/roofs are showing material and lines behind them
Tue, May 28, 2013 at 9:35:44 AM
How do you hide different material joint lines?
Thu, Sep 15, 2011 at 6:53:41 AM
joined walls in elevation
Wed, Sep 22, 2010 at 10:25:32 AM
cannot get rid of lines join cavity in wall
Fri, Sep 12, 2008 at 8:31:29 AM
Page generation time: 0.7167
