Forums >> General Discussion >> Wishlist >> Tin Roof
Mon, May 9, 2011 at 1:12:52 PM | Tin Roof
juststarting
Hi, i want to put a tin roof on my little house. I got a roof on but under materials, I don't see it.
Mon, May 9, 2011 at 1:22:43 PM | Tin Roof
4 Stars: 205 Votes
This questions is not very clear to me, can you elaborate your question a little more please?
Mon, May 9, 2011 at 2:12:23 PM | Tin Roof
juststarting
Hi, well, I just built a square 24 x 24 walls. Then I put my first roof on. It's gray. even though I do have it set on realistic.
You know the tin roofs that is on the farm houses? I'd like to make it look like that.
Edited on: Mon, May 9, 2011 at 2:14:29 PM
Mon, May 9, 2011 at 2:33:29 PM | Tin Roof
How is revit supposed to know this is a tin roof?  Read these in your HELP:
  1. Compound Structure
  2. Materials in Compound Geometry
  3. Materials
Mon, May 9, 2011 at 3:24:49 PM | Tin Roof
juststarting
Thanks, I read those. Then I clicked on my roof, materials, Roofing-Metal Standing Seam, Render Appearance tab, replace, Roofing>>
Then I see the list of shigles, spanish tiles etc. But I don't see the tin roof I want. Is there a way to make that pattern and put it there?
Mon, May 9, 2011 at 9:02:35 PM | Tin Roof
mansell5
3.5 Stars: 4 Votes
SEE link below for shaun van rooyens nice work on profiled roofs
http://revitfamilies.blogspot.com/
cheers
geoffm
Thu, May 12, 2011 at 8:55:17 AM | Tin Roof
juststarting
Thanks, that’s exactly what I am looking for.
Fri, May 13, 2011 at 8:09:47 AM | Tin Roof
juststarting
ok, I give. I have tried.
I opened profile Family template. Drew the drawing (profile) exactley liked the picture and saved. then I opened up Structural Framing - Beams and Braces.rft. I loaded the profile. It shows up in the project browser under families, profiles.
Next I deleted the rectangular that was provided. then drew a rectangular the size of the profile and extrued it. The I clicked sweep. under the sweep, the profile drop down menu is empty. What do I do next?
exposed rafter tails
Mon, Aug 4, 2008 at 7:38:57 AM
Offset roof by accident
Wed, May 18, 2011 at 1:11:42 PM
Exporting topography points from Revit to AutoCad
Thu, May 16, 2013 at 7:15:44 AM
Rendering Issue
Tue, Apr 9, 2013 at 4:35:53 PM
Roof design problems
Fri, Jul 9, 2010 at 7:30:00 AM
12
Page generation time: 4.9636
