Forums >> Revit Building >> Technical Support >> Room tag problems
Wed, Nov 16, 2005 at 11:23:46 AM | Room tag problems
Surfrusty777
I had placed room tags that were working fine when one day I opened the drawings and they all said "not enclosed". Any ideas why? Thanks, Mark
Wed, Nov 16, 2005 at 11:32:35 AM | RE: Room tag problems
TomDorner
4.5 Stars: 25 Votes
Mark, You somehow lost the room boundy aspects of your rooms. The causes can be for multiple reasons. Check that room tags are in the same phase as the walls that bound them as rooms are phase aware. Make sure that your walls are set to define room boundries. Make sure that if you have an ACAD underlay that you place a room boundy line around the perimeter of it. Other than that hard to know without seeing the file. HTH Tom
Wed, Nov 16, 2005 at 1:14:48 PM | RE: Room tag problems
Rythmick
5 Stars: 2 Votes
I use an area plan with the area analysis boundry tool to set and check all my boundries lines. I've always been able to resolve any issues going to the area view to check and adjust my boundry lines in problem areas.
Wed, Nov 16, 2005 at 3:25:58 PM | RE:
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Thanks,
Mark
Generally it will resove itself if you go to your settings and adjust the area's calculated at "height" parameter.
You can usually change it back to what it was after changing it once. It causes the model to refresh its calculations which for some reason occasionally become disassociated.
Sun, Aug 24, 2008 at 12:19:37 AM | Room tag problems
3ab8ari
Well in addition to the tips that other users gave you, I would like to add that I see this often, in models with linked models that have room-bounding geometry (i.e. walls). When a link is detached then re-attached it turns off the room bounding and you have to go turn it back on, manually.
Also, I am noticing that in random cases -inconsisten so far- that adding an opening to a wall or editing its profile turns it into non-room bounding !!
Also, is it possible that you get this just because you do not 'open' all worksets ?
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
HELP!!! Problems with Room Tag
Tue, Dec 3, 2013 at 7:17:38 AM
Editing a room tag
Thu, Oct 12, 2017 at 3:17:41 PM
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:40 AM
problems with room tags
Thu, Feb 16, 2006 at 5:12:52 PM
Page generation time: 0.6971
