Forums >> Revit Systems >> Tips & Tricks >> Complex Conduits
Mon, May 9, 2011 at 11:52:13 AM | Complex Conduits
thetabest
thetabest Avatar
3 Stars: 2 Votes
I need to figure out how to make a "rolling kick" as the guys in my company call it.  What this is:  Place a conduit at a given elevation, say 4'.  Copy this conduit to a new height, say 0', then move it some distance in the x and y direction.  What I need is to now be able to connect these two conduits with a conduit which takes the minimum path between (a straight line).
I've tried this over and over, but I can't let revit do it automatically, because it wants to drop down the 4' then path in a diagonal to the other conduit.  It seems that I struggle with Revit whenever I try to create something which changes in all 3 axis.
I'll post a dwg for further clarification once I get my hands on one...
Thanks,
Trent Best
Best Systems
the.tabest@gmail.com
Mon, May 9, 2011 at 12:30:41 PM | Complex Conduits
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
trent,
Try creating a work plane through the centerlines of the conduits, name the workplane and then you can create a view using the framing view. then you can work in that plane. to create your connections.
Mon, May 9, 2011 at 12:46:04 PM | Complex Conduits
thetabest
thetabest Avatar
3 Stars: 2 Votes
Beautiful, slight adjustment to your process, had to make a grid line instead of a work plane (so that the framing view could snap to the grid).  But then it worked!
THANKS!
Trent Best
Best Systems
Mon, May 9, 2011 at 6:00:40 PM | Complex Conduits
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
If you name the workplane the framing view will snap to it. If you do not name the view it is ignored by the framing view.
draw conduits/pipes in Revit Architecture
Wed, Feb 29, 2012 at 1:52:11 PM
Parallel Pipes and conduits
Wed, Feb 29, 2012 at 3:48:12 PM
Modeling group of conduits from one separation value to another
Wed, Aug 19, 2015 at 5:51:23 PM
Conduit Run with Fittings
Thu, Sep 1, 2016 at 3:12:57 PM
Calculatiing Overall Length of Conduit in REVIT MEP
Tue, Aug 21, 2012 at 2:35:24 PM
Page generation time: 0.6673
