Forums >> Community >> Newbies >> Setting Up Title Sheets
Mon, May 9, 2011 at 9:20:19 AM | Setting Up Title Sheets
KatyCooper
I've designed our title sheet and have all the labels set up for size A0. How can I copy this across to A1, A2 & A3 paper sizes without having to redo everything??
Thanks!
Mon, May 9, 2011 at 11:19:06 AM | Setting Up Title Sheets
thetabest
thetabest Avatar
3 Stars: 2 Votes
Parametrics... Parameterize the height and width, group together parts that need to "move", add a reference line to the group, either add a parameter to the group, or create a constraint to lock it in a relative distance from the edge...
OR the easier method:  Save as "Title Sheet A0", then save as "Title Sheet A1", etc.  Go back and resize each one appropriately...
GL
Trent Best
Best Systems
the.tabest@gmail.com
Mon, May 9, 2011 at 2:17:34 PM | Setting Up Title Sheets
Katy,
If the only thing that is different is the size of the sheet, simply edit the family and move the sheet edges on two sides then save as a new family.
Sheets Title Blocks
Mon, Jul 6, 2015 at 2:30:16 PM
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:26 AM
Title Sheets
Wed, Sep 20, 2006 at 7:08:24 AM
view title on sheets
Thu, Nov 22, 2018 at 8:28:28 AM
Importing AutoCad title sheets?
Fri, Sep 12, 2008 at 12:48:09 PM
Page generation time: 2.0240
