Forums >> Revit Building >> Technical Support >> How do I load a floor plan from another Revit project
Fri, May 6, 2011 at 9:26:28 PM | How do I load a floor plan from another Revit project
ksmith
Hi, I'm having difficulty in loading a floor plan from another of my saved Revit projects. Is there a way to do this? I have created an A3 sized sheet and I want to add different plan views to the sheet. However, a couple of the other views that I want to add are not in the same project that my sheet has been created in.
Not sure how to get around this. Can it be done?
All help appreciated.
Thank you
Kirk
USING REVIT 2011--- This old builder is determined to Learn Revit no matter what it takes.
Mon, May 9, 2011 at 1:44:19 PM | How do I load a floor plan from another Revit project
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
There are multiple ways to approach this:
1. 'Insert' tab and Insert the entire sheet of floor plan that you need.
or
2. Export the plan in CAD, and import it in the new Revit file, in a drafting view.
Mon, May 9, 2011 at 1:59:03 PM | How do I load a floor plan from another Revit project
If you are talking about a titleblock, you can transfer that to your project and use it.  One way of doing this is to open both projects at the same time, find the titleblock and copy to clipboard, switch projects and paste it in.  Now it will be in your browser for your use.
Mon, May 9, 2011 at 2:47:51 PM | How do I load a floor plan from another Revit project
ksmith
Thanks for this. I'm actually now trying to insert an actual floor plan and also a 3d view of my model into the other project. When I try to do this via the insert link, Revit says it cannot import models, or something to that effect anyway.
I was hoping this was possible, unless I'm getting this totally wromg here.
Thanks
Mon, May 9, 2011 at 2:59:29 PM | How do I load a floor plan from another Revit project
You can link the model in.
Tue, May 10, 2011 at 3:31:09 PM | How do I load a floor plan from another Revit project
ksmith
Thanks WW
Works well
Thu, Aug 11, 2016 at 5:49:41 PM | How do I load a floor plan from another Revit project
Kdoxey
I know this is super old, but if you create the view in the linked model you can set the view in the parent project to by linked view to view the same view that was set up in the linked model.
Family don't show up in floor plan once load into project
Wed, Oct 20, 2004 at 1:35:51 AM
Create sub menu in Project Browser Floor Plan Views
Tue, Jan 1, 2013 at 8:34:40 PM
help! cannot load new column family into project
Wed, Jul 16, 2014 at 12:26:38 PM
create a floor load diagram?
Tue, May 28, 2013 at 3:38:28 PM
Strangest Revit Floor Plan / Level Problem - Not a newbie question
Wed, Oct 4, 2017 at 1:59:11 PM
Page generation time: 3.2189
