Forums >> Revit Structure >> Technical Support >> HSS column hidden lines not showing up
Fri, May 6, 2011 at 6:01:37 PM | HSS column hidden lines not showing up
Crackerjack
Crackerjack Avatar
Hey there,
I've got a 1:10 steel roof framing section with a w-beam framing into an hss column.  The hidden lines from the inside wall of the hss are not showing up.  I've tried everything to get them to show up, without any success.  My detail level is set to 'Fine', the Model Graphics Style is set to 'Hidden Line'.  I've checked my visibilty settings for column hidden lines in the visibility setting and object styles, and made sure they are checked on.  I don't know what else to check?
Any ideas?
Thanks
Trev
Sat, May 7, 2011 at 4:34:57 PM | HSS column hidden lines not showing up
Crackerjack
Crackerjack Avatar
Update:
So I figured out that the hidden lines shown up when I look at the column 90 deg to the view.  Which means they only show up in one direction for the HSS column, wierd?  Seems like this is some kinda glitch with the family.  I ended up rotating the hss 90 degrees in the section and the hidden lines 're-appeared.
Foundation lines showing up hidden
Thu, Jul 12, 2012 at 4:55:00 PM
Show Hidden Lines Tool and Detail Elements
Fri, Nov 22, 2013 at 8:48:50 AM
Hidden Lines disappeared from all my Elevations
Fri, Mar 1, 2013 at 12:37:04 PM
show hidden lines
Fri, Mar 4, 2011 at 2:17:59 PM
Hidden Lines not showing.
Tue, Apr 30, 2013 at 8:59:13 AM
Page generation time: 1.6033
