27 Users Online (25 Members):
Forums >> Revit Systems >> Technical Support >> 2011 revit arch won't load families out of the imperial library
I want to insert the actual steel that the engineer specd
when i try and load a particular size of any of the structural componets I get a message telling me that it cannot load the family
The problem is that you've probably gone to "column" and then the "load family" button. What's happening is that you're asking revit to load a structural column family into a architectural column... identity. So it's saying no.
So, If you go to the insert tab, you can load families there, no strings attached. Or if that fails for some reason, you can just open/edit the structural family directly, and tell it to load into your project that's open in the background.
that is a big change from the way you used to be able to do it
thanks
Profile folder locations |
Fri, Aug 1, 2008 at 9:17:50 AM
IMPERIAL LIBRARY |
Mon, Apr 7, 2008 at 4:54:49 AM
Families won't load? |
Tue, Sep 2, 2008 at 1:17:06 PM
Library Components, Metric and Imperial |
Mon, Apr 30, 2012 at 12:38:59 PM
update imperial library files |
Mon, Mar 15, 2010 at 3:05:40 PM
