12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Unhiding all objects in a view
Hi All,
Is there a quick and easy way to unhide all elements in a view without selecting the objects first? Normally I would simply enter the Reveal Hidden Elements mode, use a selection window to highlight everything at once, and then click unhide all. Unfortunately I have some elements (demolition infills) that can not be selected, whether in or out of Reveal Hidden Elements mode. The goal is to unhide a few chunks of infill that we have previously hidden, but we can't seem to grab on to them to unhide them. Any suggestions apprecitated!
Thanks
Revit Architecture 2011
UPDATE: After pursuing this a bit more in the office, we did manage to solve the issue by selecting the infill in a different view, then went back to the problem view with the element still selected and clicked unhide. It still would be rather helpful to know if there was a simple way to unhide all elements in a view without having to select them.
14 Posts No Rating |
Hi
I am almost new in revit , i have a problem, in one of my level i miss all furniture and trees but they show in other down and up level of that! Any one know about that, i dont hava any temporary hidden in that level!
Revit 2012
HI Choona
there are 33 or more reasons (according to others) why we element is not showing. so you must indicate how did you model it. is it link? does it have workset? filters? etc...
-mostly, Visbility Graphics (VV) issue. try to check it all.
-check view range.
-sometimes if i cant make it appear. i will create a view template from a correct view and apply it to the affected view.
** dont be mad, i dont have much... i am homeless |
Thanks ronmalit
Actually i solved my proplem ,my problem was one of the 33 issue ,I hided those objects, but, because I didn't see ke blue windows that shows hiding object, i pushed the smail bulb bottom under the page and a red windows apeear with all of my objects which were red.! I thought they were disapear, any way, thanks
Section View with missing objects at certain height! |
Tue, Mar 10, 2009 at 10:41:04 PM
Objects showing in wrong plan view |
Sun, Oct 10, 2021 at 8:10:49 AM
missing walls |
Wed, Dec 10, 2008 at 2:27:51 PM
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects |
Fri, Oct 12, 2012 at 7:31:58 AM
Find objects in views using "Select All Instances in View" |
Tue, Sep 3, 2024 at 5:10:21 AM
