Forums >> Revit Building >> Technical Support >> Cutting a Massing Cube with a slice in the corner
Fri, May 6, 2011 at 8:41:38 AM | Cutting a Massing Cube with a slice in the corner
ChChChChela
ChChChChela Avatar
I am doing a massing model and we are slicing the corner.  I am having a hard time doing the slice at a 45 degree angle.  Does anyone have an easy way of doing this?
Edited on: Fri, May 6, 2011 at 8:44:21 AM
Fri, May 6, 2011 at 1:19:55 PM | Cutting a Massing Cube with a slice in the corner
4 Stars: 205 Votes
Something like this?
VOID BLEND
Sat, May 7, 2011 at 5:07:10 AM | Cutting a Massing Cube with a slice in the corner
4 Stars: 205 Votes
Another solution: http://screencast.com/t/nLzF48zlOpJt
slice massing object?
Wed, Apr 6, 2005 at 2:56:21 AM
Conceptual Massing Loading Problem
Thu, Sep 19, 2013 at 12:13:40 PM
how to add an edge in an conceptual massing
Sun, Jul 24, 2011 at 2:36:43 AM
Memory Issue? Elevation view from view cube
Tue, Mar 8, 2016 at 3:16:45 PM
Corner guards to snap to corner of wall
Tue, May 13, 2014 at 12:18:44 PM
Page generation time: 0.1373
