Forums >> Workflow & Implementation >> API & Third Party Apps >> external file reference (2012 api)
Thu, May 5, 2011 at 9:21:54 PM | external file reference (2012 api)
paulh
I've been using the following code to try and get the file directory of a linked DWG file that the user has selected:
if(sel.Elements.Size == 1){    System.Collections.IEnumerator es = sel.Elements.GetEnumerator();    es.MoveNext();    Element el = es.Current as Element;    if (el !=null && el.IsExternalFileReference())    {        ExternalFileReference efr = el.GetExternalFileReference();        directory = ModelPathUtils.ConvertModelPathToUserVisiblePath(efr.GetAbsolutePath());    }}
However el.IsExternalFileReference() never returns true. Has anyone had any luck using this new API feature?
Revit API External Applications
Mon, Sep 22, 2008 at 7:19:13 AM
Revit 2013 API
Mon, Dec 31, 2012 at 10:32:36 AM
Add size_lookup formula via Revit API
Mon, Mar 21, 2016 at 8:53:25 AM
Link to External Files in FamilyParameter Formulas
Mon, Jan 28, 2008 at 9:20:38 AM
API?
Fri, Apr 27, 2007 at 4:43:35 PM
Page generation time: 0.5581
