Forums >> Revit Building >> Technical Support >> the incredible shrinking beam
Thu, May 5, 2011 at 3:06:59 PM | the incredible shrinking beam
pixelpete
I have inserted a structural beam between two other beams, and need for this newly inserted beam to fit tight against the two beams.  I pick the beam center lines as insert points, which should place the new beam tight to the others, but when I'm done, the new beam shrinks back 4 or 5 images on each side.
I don't understand why the beam is automatically shrinking back from my insert points.  I have tried inserting the beam 5 inches to the outside of the beam line, but it still doesn't insert the way I want it to.  Any ideas?
I'm using Revit Architecture 2011.  Thanks.
Thu, May 5, 2011 at 3:22:24 PM | the incredible shrinking beam
pixelpete
I think I figured it out.  I moved the left/right arrow in plan view to the desired location, and that moved the model correctly.  I used the cope tool, and all is well.
Thu, May 5, 2011 at 6:40:16 PM | the incredible shrinking beam
thetabest
thetabest Avatar
3 Stars: 2 Votes
Not from structural, but I believe this is happening due to your structural settings...  Look through these, (should be on the manage tab, but yet again, I don't have structural so not 100% sure).  Somewhere in the settings, you should be able to set the gap, and this value is what your beam kept setting itself to by default.  I think your solution might have overriden this default value...
GL
Trent Best
Best Systems
the.tabest@gmail.com
Sloped Beam Connection
Thu, Feb 21, 2013 at 11:13:15 AM
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:16 AM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:48 AM
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:36 PM
Beam & Beam systems
Tue, Oct 21, 2008 at 4:36:54 PM
Page generation time: 0.3027
