Forums >> Revit Building >> Technical Support >> Patern Files
Wed, Nov 16, 2005 at 2:35:28 AM | Patern Files
Audrie
I find the pattern file for earth to be too large for my 1:100 sections and prefer it at a 45degrees. How does one rescale and angle the pattern files. Revit appears to only give me the option to recreate it from scratch.
Wed, Nov 16, 2005 at 2:53:56 AM | RE: Patern Files
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes once they are imported they are as is.... You need to re-import the custom pattern and scale on import. This is the only time when you can scale a custom pattern. You can't rotate custom patterns either
Scaling Patern files
Fri, Apr 20, 2007 at 5:47:27 PM
Rotate surface pattern on a model-in-place blend
Fri, Mar 16, 2012 at 3:43:20 AM
Colouring of Generic Model Patern Based Wall
Thu, Jan 12, 2017 at 12:24:32 PM
11
How to make ceiling grid with a pattern on it
Mon, Aug 11, 2008 at 2:21:07 PM
surface patern not aligning
Fri, Jul 20, 2007 at 9:38:40 AM
Page generation time: 0.1815
