18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Section title line showing wrong reference sheet
8 Posts No Rating |
I have experience a few difficulties on section title lines.
The reference tag is showing a wrong sheet of plan, and not editable (Instead of reference ground floor plan, it referenced the basement plan which is not very helpful). They appear to be very random, or there is logic that I can't follow.
Is there a way of edit the tag? or somehow make the tag appear appropriate sheet? cos currently I just put a filled region and write on top.
Any help would be appreciated!
I have not seen Revit make any errors on referencing so if this is wrong, then maybe you have made an error somewhere.
Your sheet numbers are the true sheet parameter number and not just text, correct?
Your views are placed on sheet views - correct? (In other words, you have not drafted titleblocks in your views. - Some beginners still approach Revit like CAD and make this mistake. )
Please upload an image.
I've seen components display incorrectly their level, but I've NEVER seen it happen with a view. The only way I could even conceive of this happening, is as follows:
Create a level, name it Fred
Create a view from that level, and it will also be named Fred.
Now go back and change the level's name to Joe, when prompted to change view titles, decline.
Now you have a condition where you view is named after an old level name... so you could have a basement view, which is actually associated with a level 1 because the level was renamed at some point...
Trent Best
Best Systems
the.tabest@gmail.com |
Showing wrong reference sheet on view title |
Wed, Oct 17, 2018 at 12:26:30 AM
14
Revit 2009: Custom label in title view & Reference sheet |
Mon, Dec 8, 2008 at 7:09:23 PM
How to link a Revision Schedule on Title sheet with Title Block |
Fri, Jan 11, 2013 at 7:26:26 AM
Section line disappears from plan when section view is placed on same sheet |
Thu, Sep 4, 2014 at 7:46:20 AM
titles not showing up in viewports |
Fri, Jan 5, 2007 at 2:36:39 PM
