Forums >> Revit Building >> Technical Support >> Render - Lumincent Image - Interior Scene
Wed, May 4, 2011 at 3:36:26 PM | Render - Lumincent Image - Interior Scene
MattEarl
5 Stars: 2 Votes
Hello all,
I've recently started doing some interior render scenes for a project, and one happens to have a TV in the background, now with low lighting, the image is dark as well.  Since this Image is "mounted" on a TV family, is there a way to make the image Luminescent?  I've tried actually adjusting the decal inside revit for Luminosity, but it just turns white.
Any suggestions?
Thanks, Matt
Mon, May 9, 2011 at 3:59:33 PM | Render - Lumincent Image - Interior Scene
DeifyMe
4 Stars: 2 Votes
I've tried this before with a Decal without any success. I ended up creating a new material and used my Picture file as the material pattern. "Edit Image" and scale it to be the size of your TV screen. Then check on the self-illumination setting and ticker with those values. It will appear bright but it won't illuminate any of the surroundings unless you make it a light source under it's Family Categories. I hope this helps.
Revit 2009 interior rendering isue [ 1 2 ]
Wed, Sep 3, 2008 at 4:29:43 PM
23
HOLLOW WALLS IN 3D INTERIOR RENDER
Wed, Oct 31, 2007 at 10:31:11 AM
INTERIOR render
Tue, Aug 23, 2011 at 3:10:20 AM
External Lighting Night Scene
Mon, Oct 26, 2009 at 2:09:22 AM
Exterior Render-Interior too dark!!
Tue, May 4, 2010 at 7:31:50 AM
Page generation time: 0.4590
