Forums >> Revit Building >> Technical Support >> Adjustable Section Tails
Wed, May 4, 2011 at 1:09:40 PM | Adjustable Section Tails
ALICEHER
Hi All,
I was wondering if it was possible to change the length of a section tail. I would like the tail to extend past the top of my wainscot. Any suggestions?
Thanks.
Wed, May 4, 2011 at 1:22:08 PM | Adjustable Section Tails
thetabest
thetabest Avatar
3 Stars: 2 Votes
In the browser, expand families, annotations, you will find a section tail somewhere in there.  Open this, edit it, save it as a new type, or add parameters to it and make it parametric, load into project.  Go to manage tab, select additional settings, section tags.  Create a new type, or modify an existing one, select for the tail the one you just modified/created.  Go back and look at your view, adjust until you have the desired results.
Trent Best
Best Systems
the.tabest@gmail.com
Wed, May 4, 2011 at 1:29:44 PM | Adjustable Section Tails
Just grab the tail and drag it to where you want.  The tail and the view crop are sperate after initial placement.
Revit 2009 : Section Tails: How to create custom Section Tails
Thu, Jul 17, 2008 at 3:25:05 PM
Section and Detail Tails
Sun, Jun 18, 2006 at 9:30:05 PM
Section Cut tails
Wed, Mar 28, 2007 at 1:46:10 PM
Section Cut heads and tails automatically toggle on when you adjust crop region
Wed, Oct 10, 2007 at 11:45:19 AM
Rafter Tails
Thu, Jul 26, 2012 at 1:22:23 PM
Page generation time: 2.4795
